Firenzi FIDW41 Not filling
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Firenzi FIDW41 Not filling
Viewing 15 posts - 1 through 15 (of 18 total)
  • #8907
    Have a Firenzi FIDW41. It has stopped filling properly, resulting in very poor spray (no power) and unwashed stuff.
    At the point it starts filling if I chuck in a bowl of water it works OK (until it needs to refill again).
    When working, how does the machine know when it has the correct quantity of water? Is there a pressure/level detector or is it some other way?
    I’ve checked the cabling (I am an electronics engineer before the well-meaning and quite valid voltage warnings 🙂 ) between the switching mechanism and most – difficult to check all without pulling it out… – solenoids/sensors etc.
    I’ve also done a cursory check of the pipes for blockages and cant see anything. One big clue is that the cycle continues even tho there is not enough water in it; why does it do this, surely the timer stops until it detects the correct water-level?
    Many Thanks
    Mat
    #131049
    lotusray
    Re: Firenzi FIDW41 Not filling
    I DONT KNOW MAKE OR MODEL BUT SOUNDS LIKE PRESSURE CHAMBER BLOKED OR PRESSURE SWITCH FAULTY
    PRESSURE CHAMBER FAV ON A DISHWASHER
    #131050
    Cheers Lotusray… I dont suppose anyone knows where the pressure-switch is on a FIDW41? I’ve had a good shwish around and checked blocked pipes etc, but not found anything obvious.
    I’m suspecting the switch rather than than chamber, but only because I dont know what a dishwasher pressure chamber is (and i’ve checked pipes/cavities)..
    #131051
    I Googled for this model and all I came up with was an Acrobat Document listing all the models and all the units to fit them in so I would guess that it is supplied from something like MFI or similar.
    Oh and the only other thing that Google came up with was a link to UKWhitegoods. 🙂
    To be honest the way dishwashers control their water levels varies greatly from model to model, even within a single manufacturers range of appliances. Most have some form of pressure switch, but some have timed fills as well. Others have an inlet valve and safety level switch in one unit that can cause similar faults.
    I would guess that someone will know who actually produced this machine and be able to advise you further.
    Is there anything on the rating plate such as place of manufacturer etc that could be a clue.
    Edit..Just followed the link from google back to here and it would appear that your machine is a Zanussi. 8)
    #131052
    Mat,
    You are looking for a small chamber on the r/h side at the bottom of the machine, with two hoses and two round blocks attached to it – these are the pressure switches and chambers. They must be clean of all residues, also check feed hoses running back across the machine.
    Safety first……..
    gegsy
    Firenzi is usually a whirpool hybrid if that helps
    Dave_Conway
    This one isn’t, I checked earlier 🙁
    I have no idea of the manufacturer of this model :con:
    #131055
    gegsy
    With any luck it won’t be a Kenwood or Teka
    :eeek:
    gegsy
    Let’s regress……….. this may help viewtopic.php?f=33&t=3825
    Dave_Conway
    Hmm, I’m intrigued now 😉
    Can you take a piccie of the insides Mat with the door open (baskets etc) and one of the control panel and email them to me please.
    #131058
    Dave_Conway
    Zanussi then 😀
    I ought to use the search facilty more often 😉
    Which will probably mean a new IWMS 😯
    #131059
    It’s a chuffing Zanussi – it’s on TDS and it doesn’t have the usual IWMS – it’s got a separate double pressure chamber set-up with double pressure switches. Bet it’s still sludged up though.
    gegsy
    The appliance of science :rotl:
    #131061
    The I link mentioned in post #4, from google, to UK Whitegoods is the same one that gegsy has posted. 😉
    #131062
    gegsy
    iadom wrote:The I link mentioned in post #4, from google, to UK Whitegoods is the same one that gegsy has posted. 😉
    Ive been rumbled our kid 😆
