Re: Firenzi FIDW41 – product code 911931002
No that doesn’t sound normal…you can check to see if the door is sealing correctly by having a good listen when its washing…if you press on one side of the door and then the other, check that the sound of the machine doesn’t change. If it does it means that the door catch may need adjusting, or it may have been poorly installed…occasionally I see built in dishwashers with the top mounting screws hanging down preventing the door from closing fully.
Incidentally, it is worth getting sorted quickly because the steam can damage some worktops.
Hope that helps?
Clive
