Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Firenzi Fridge Freezer.. fridge getting warmer
- This topic has 7 replies, 4 voices, and was last updated 19 years, 2 months ago by
ag.
February 6, 2007 at 10:43 am #24809
ag
ParticipantHelp!
Typical warranty just run out and being a tightwad didn’t want to pay the huge amount requested to keep it going! 😳 But the fridge part is now getting warmer or rather not keeping things as cold as it should. Any ideas what it might be? (freezer is fine)
February 6, 2007 at 6:15 pm #203376jed
ParticipantRe: Firenzi Fridge Freezer.. fridge getting warmer
what’s the make and model?
February 6, 2007 at 6:54 pm #203377ag
Hi Jed
It’sa Firenzi fridge. Model number FCB285. Bought through Magnet Trade if that helps.Any ideas?
February 8, 2007 at 2:34 pm #203378ag
Any ideas?
One thought (having read through the info stuff on this site) could the pipe thing at the back be blocked? At the back of the fridge part there’s a hole which presumably drains some of the water out… could it be that? If so, can I clear it? how?
February 8, 2007 at 10:37 pm #203379ag
OK I’ve read all the comments about fridges being too warm.. quite reassuring it’s not just me!! 😆
I’ve poked around the draining hole with electrical tie thingy and also defrosted the fridge/freezer properly. Have just switched back on so fingers crossed will be colder when all done.
Should I try anything else? Any other tips?
Anna
PS Thanks soooo much for this site – it’s full of tips and tricks of the trade.
February 9, 2007 at 12:28 am #203380Penguin45
Anna,
Sorry you haven’t had a specific response to your problem. It’s always a problem who is on line at any given time on a voluntary site. I regret I can’t add anything.You may wish to consider using the link below to find a UKW approved engineer in your area.
Penguin45.February 9, 2007 at 12:49 am #203381kwatt
KeymasterRe: Firenzi Fridge Freezer.. fridge getting warmer
Hi Anna,
It’s liable to be either a blockage or a compressor failure and you’d need someone to confirm that for sure. It’s not likely to be a thermostat failure or anything that you can solve on your own I’m afraid.
February 9, 2007 at 8:23 am #203382ag
Hi Penguin45 and K
Thanks for your replies. I did email the ‘approved engineers’ through the site unfortunately none of them were able to assist.
Yellow pages it is then for clearing the blockage or replacing the compressor.
Thanks muchly.
A
