Re: Firenzi FWD1200 – Program dial sticks
What you have here is the “Trade” version of the Lux EW1200i – a Zanussi machine. If you are lucky, the knob and indicator will simply be gunked up. If you are unlucky, the timer itself will be sticking. To check the former:
With the knob in the “out” position, hold it firmly with one hand whilst rotating the cap on the front anti-clockwise. It may well break, but it’s cheap. With the cap off, the knob can be unscrewed by the small nut, and the indicator can be unclipped from the cam underneath. Clean everything – all components removed and the hole in the control panel where it all fits. It takes surpisingly little grease to render the mechanism virtually inoperable.
If this makes no difference, it’s the programmer itself. Get back to us on that.
