Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Firenzi Integrated Dishwasher
- This topic has 14 replies, 7 voices, and was last updated 21 years, 2 months ago by
admin.
February 9, 2005 at 9:58 pm #7863
KeymasterI ahve a Firenzi integrated dishwasher which I am having problems with. Unfortunately cannot find the model number on it or the instuction manual. It is stopping after a short time and the right hand green light then flashes on and off continually. It stArts again when I press the right hand button it but stops a couple of seconds later. It is not washing anything. Can anyone tell me if I am doing anything obviuosly wrong with it and how I might go about fixing it?
ThanksFebruary 9, 2005 at 10:08 pm #125531Penguin45
ParticipantCheck around the edge of the door Sue, also top of the cavity – there’ll be a label somewhere.
Problem is Firenzi is not a manufacturer; the appliance will be bought in and “badged” – we will need to work out which one you’ve got before we can offer any real advice.
Regards,`
Penguin45.February 9, 2005 at 10:16 pm #125532admin
KeymasterRe: Firenzi Integrated Dishwasher
Thanks for the quick reply. I have found a number. Hope this is the right one! DW928WH
Many thanks
February 9, 2005 at 10:24 pm #125533Penguin45
ParticipantSounds good, see what we can find out – probably not tonight though!
Penguin45.February 10, 2005 at 10:25 am #125534Dave_Conway
ParticipantRe: Firenzi Integrated Dishwasher
This ia a Whirlpool made dishwasher.
The flashing light indicates there is a fault Sue which will need an engineer’s attention. Most commonly it’s the NTC (temperature sensor) which isn’t a major job to put right.
Please try repairs@ and the directories and see if there’s one in your area, or pop up your postcode.
Hope this helps.
February 10, 2005 at 7:34 pm #125535admin
Thanks so much for your advice and help. I will conatct someone straight away to get it fixed.
November 9, 2007 at 9:14 am #125536nickell
I had the same dishwasher a few years and we’re not impressed so far.
I constantly check and put salt in as well as rinse etc. I have put through one of those “Dishwasher washer” bottle as well. So the inside looks clean
But recently it just isn’t cleaning. Usually leaves what looks like grit in the glass and cups.
Any one any ideas?
Paul
November 9, 2007 at 9:35 am #125537Simon46
Food debris stuck in the spray arm holes usually.
Regards
SimonNovember 9, 2007 at 10:50 am #125538nickell
Thanks Simon. I’ll try that.
Paul
July 28, 2009 at 9:42 am #125539kenningcat
I’m about to purchase a Firenzi Integrated Dishwasher (brand new but second hand). If they’re made by Whirlpool, can I assume that they’re as good as Whirlpool dishwashers?
Thanks,July 28, 2009 at 9:51 am #125540kwatt
What model and we can check for you?
July 28, 2009 at 11:17 am #125541kenningcat
Hello,
The model number is apparently FIRWDW42.
Many thanks,July 28, 2009 at 11:24 am #125542kwatt
KeymasterNope, that one’s an Electrolux. 😉
July 28, 2009 at 11:38 am #125543kenningcat
Thanks. Do you know if it’s any good? (Should I assume that it’s as good as an Electrolux)?
July 28, 2009 at 11:43 am #125544kwatt
KeymasterSame thing only different, specified for Firenzi, I’d assume pretty much the same.
