Firenzi Oven cuts out!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Firenzi Oven cuts out!
  • #30443
    Samjay
    Hi, This is my first time posting here, and I hope someone can help. We have had a Firenzi electric fan assisted oven Model: FSF650WH; Serial No. 522 11091 for two years. There is no cooling fan mentioned in the manual and I cannot see any. The oven has started to cut out intermittently, tripping the MCB in the consumer unit at the same time. The first time was after an hour into cooking, and the second time was after ten minutes into cooking. Any advice as to the cause and a possible solution would be great. Thanks!
    Samjay
    #227226
    Re: Firenzi Oven cuts out!
    Oh we love these ones, intermittent tripping. 😉
    The first most obvious thing to look for is an overheat stat, that would be my first thought.
    After that you’re really into some detective work with a decent meter and a bit of knowledge TBH but it could, almost literally, be anything if the cause isn’t obvious.
    It can be very hard to track down a fault like this and my advice would be that, if it isn’t obvious, call in a pro.
    Samjay
    Thanks for your very prompt reply. Think I’ll call in the pros.
