firenzi (whirlpool) inner oven door glass
Home Forums Public Support Forums Help And Support Cooker And Oven Forum firenzi (whirlpool) inner oven door glass
  • #14551
    maddog22
    I need to glue the inner glass to the large oven door on a Firenzi DO 903 WH.
    Found out from this excellent site how to remove the door..so far so good.
    There are two small screws in the bottom edge of the door and I have removed these but the two halves of the door refuse to come apart…I’m reluctant to use force since glass is involved..is there a trick to this and should I glue it or buy a new inner door part?
    #159872
    Dave_Conway
    Re: firenzi (whirlpool) inner oven door glass
    I’ve successfully glued lots of them, just make sure the surfaces are very clean.
    The door will be a bit tight but does come apart 😉
