This machine starts the cycle, heats up and washers but fails to drain and just stops with water in the draw bottom. There are no error codes emitted. The pump on these machines washes and drains I believe. Has anyone got thoughts on what the fault is. This fault is on the top draw only, the bottom draw works OK. Any information would be appreciated. How is the draw removed to gain access to the circuit board etc?
Went back to check this machine as it was bugging me. One of the two drain hoses was blocked with fat. Strange how only one was blocked at the Y Connector.
