Re: Fisher and paykal smartdrive error code 49
Hi, again thanks for the help. It turned out that a water leak was the problem and the control board was wet. The grommet that holds the incoming water temp sensing thermocouple was leaking into the area under the control module. On drying the module out everything worked fine. Silicon around the grommet and all is good.
Have you seen this grommet leak before. Why is there not a drain away from this area? Even a hole to the floor would be better than flooding the control panel. The leak was only 4 or 5 drops per minute and only when water was being put into the tub.
Thanks again.
