Fisher and Paykel 701 Smartdrive
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher and Paykel 701 Smartdrive
  • #28660
    ausmuz
    Good morning from Australia
    We have the above washing machine. The error message is
    130 ( 10000010). Machine stops at any spin cycle, although water seems to pump out ok. (I’ve actually put a new pump in in the hope of fixing the problem, but no) Bowl tries to start up to spin, but gives up. Checked through your archives, didn’t spot this error. Thanks for your time,
    muz
    #219485
    bigsmokepiker
    Re: Fisher and Paykel 701 Smartdrive
    Fault Code130
    Rotor Position Sensor (RPS)Error
    Likely causes are bad Connection at Wiring harness
    Faulty RPS (corroded Terminals Usually )
    Faulty Motor Controller (MAin PCB)
    Check Wiring Harness especially At RPS (RPS is located near Motor under bowl )
    Check for Signs of Water leakage
    Main Seal can give way leaking slightly onto RPS
    If This is All clear Etc Then Unfortunately seems like Motor Controller
    #219486
    Hi Ausmuz & BSP
    Penguin will answer these when he has swapped nursing his eggs with his missus later today or this evening.
    Bryan
    #219487
    😀 BSPs answered the question……….
    Anyway, off to the Oz forum.
