Don’t know a huge amount about these strange beasts, but I’m hoping someone on here does. Went to this “badge” type machine with the flood switch activated. After mopping out, I found the top drawer leaking on fill, so I’m assuming it’s a leaky fill hose. Bottom drawer ok. A few questions:
Part no. of the hose?
Where can I get one from?
How do I get into it?
If it is a major leak then it will probably be the fill hose but if there is not too much water it will be the drain hose. When the fill hose goes it normaly bursts apart and is normaly caused by a blocked softener unit.
PM me your email address and I will send you some info.
