This washer stopped midcycle, and won’t start up again.
I pulled up diagnostics mode and got Error Code 34 (00100010). Could someone help me diagnose this?
I can give all the other numbers as I cycled through the spin cycle buttons if needed. I can also get hot and cold to run, and the machine to drain in diagnostic mode.
34 is to do with the drum braking circuits – appears to relate to the motor controller board, Tech says replace. If that doesn’t work, replace the display board. If that works, put the original motor controller back in……..
Penguin45 wrote:34 is to do with the drum braking circuits – appears to relate to the motor controller board, Tech says replace. If that doesn’t work, replace the display board. If that works, put the original motor controller back in……..
