Fisher and Paykel GW603U Has Error
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher and Paykel GW603U Has Error
  • #14857
    MrT
    I have just replaced the Controller Module on my GW603-U Product 93975 Serial No: RAL622923 due to an internal fault. It now comes up with the LEDS 1101001 and the Slow and Hold LEDs on. Any help would be appreciated.
    Ian
    #161092
    MrT
    Sorry the correct error code on power up is 1010001. The controller module part the store gave me was 426204P. They said the one I had was superseded. If some one want to email me direct.
    ian.turner@iinet.net.au
    #161093
    Re: Fisher and Paykel GW603U Has Error
    Error code should read 8 digits – can’t recognise either of the ones you’ve posted. However, the new board needs to be accurately located on the plungers in order to activate size switches. Additionally: Hold down “Start/Pause”, then push “Power”. Count to 10, power off. This should reset the size in the EEPROM in the computer.
    If no joy, run diagnostics and post the 8 lamps, right to left.
    MrT
    Where are these plungers? I puchased a new module that came in the yellow casing. I can’t seem to get it into any modes. The only error codes I get up left to right are as I mentioned. 01010001 and 01101001. Start?Pause and Power hold down doesn’t seem to work either. Help!!
    #161095
    Right, now you’re talking….. These are comms errors between the motor board and the display board. Beyond checking for continuity/correct location of connectors, it all gets a bit technical – either board could be causing the problem. I’d start by asking them to exchange the new board – if you’ve still got problems it’ll have to be the display board.
    Time for pro help perhaps?
    MrT
    Thanks for the help. In the beginning before I replaced the Controller module, the fuse blew and I inspected the controller module and the PCB was slightly cooked. Do you think this may have taken out the display module? I will go to the store tomorrow and ask for a replacement module.
    #161097
    MrT wrote:Do you think this may have taken out the display module?
    Can’t speak with great authority on that one. However, we have an endemic problem over here with Zanussi front loaders – when the main board blows, it’s a 50/50 that it’ll take the display board out as well – gets horribly expensive.
    Good luck,
    MrT
    Just been to the spare parts store. Supplied me another new controller module. He tells me I do need a new display module to work with the new controller module. But they have no stock until next week. Will have to wait until then as the washing piles up.
