Hello all,
My F&P GW701-U washing machine has developed the follwing fault – when it gets to the rinse part of the cycle the pump spins but the the bowl does not fill. If you advance to final rinse it will rinse but it will not spin dry correctly…does not get up to top speed & stops spinning too early…and sometimes then goes back one step to the final rise cycle.
Fault code is 0010 0101. hope somebody can help.
