Fisher and Paykel Gw708au error 43 but not oob switch ?
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher and Paykel Gw708au error 43 but not oob switch ?
  • #34468
    satcheee
    Hi people i would really like some help
    i have a fisher and paykel gw708au and i have error code 43
    so i replaced oob switch and still comes up with code i checked pcb board and theres no corrosion and it looks like new i just cant fiqure this out !!
    there is still 5 volts on the oob circuit leads and connections are Fine
    my symptoms are
    the machine wash’s, rinses but when it comes to spin it tries 3 times and then beeps
    also sometimes it will spin and sometimes it wont ?
    IS there any other error for code 43
    any help would be VERY grateful
    Thanks in advance
    Lee
    #242792
    Re: Fisher and Paykel Gw708au error 43 but not oob switch ?
    Tub bias spring is attached? If not the tub can move excessively and hit the lever. If yiur sure that the wiring is correct the fault probably lies in the motor controller board itself.
    satcheee
    Penguin45 wrote:Tub bias spring is attached? If not the tub can move excessively and hit the lever. If yiur sure that the wiring is correct the fault probably lies in the motor controller board itself.
    hi penguin yes tub bias spring attached i have blown sensor tube as well
    i just tryed another motor board and it shows a 1001000 code 9
    error i tryed your temp up and spin to 7kg trick no good !
    this machine is 7.5kg
    so it washes rinses pumps out but when it comes to spin it revs up goes about a min then slowsdown then retrys sometimes on the next time it may spin other times it completes the 3 and starts to beep
    i notice when i stick it on auto water level it fills to the top whilst checking along the way !!
    you must have seen this problem before or someone must have
    hope to hear from you soon
    thanks
    Lee
    #242794
    9 is the size error, board will not work if size not set.
    Procedure for your machine:
    Press and hold “Temp up”, then press “Power”. Use “Speed Up” button to illuminate the “Hold Spin” led, then press “Power” again.
    satcheee
    i notice when i stick it on auto water level (AND THERES NO CLOTHES IN THERE) it fills to the top whilst checking along the way !!
