I have a Fisher and paykel GW798U. Part way into a wash it starts beeping and the 3 led’s come on, the short wash, the 2nd rinse and the spin. Can any one tell me what the problem is. I have looked under the controle panel cover for the diagnostics info sheet but its not there.
Any help with locating the faulty component would be much apreciated.
Cheers.
Terry aka wallydag
I think you’ll find that’s fault 11. It’s a water level control issue. With the machine fully empty, check that the air hose to the level switch does not have water in it, is not holed, kinked, trapped or blocked. The water level switch itself may be at fault – this is part of the motor controller board, so if it has failed, replacement of the whole will be required,
