Re: MW059AU error code 60
Thanks Penguin on interpreting error code, appears I can’t add up or type.
Removed the pump and it runs ok on mains power.
Inspected the two Triacs that control power, they appear ok. Have also manually controlled pumpout from front panel.
Have checked all diodes and they appear ok, even paralleled corroded pcb track with hookup wire, but repair illudes me.
Also how do I cancel flashing leds when washing machine is turned “on” at the power switch.
Can anyone help give me another clue other than replacing control board.
