Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher and Paykel MW511 replace & program motor control
- This topic has 2 replies, 2 voices, and was last updated 17 years, 8 months ago by
fyodor.
August 13, 2008 at 9:36 am #38718
fyodor
ParticipantHi
I need some advice on how to program a new Controller board for insertion into my MW511.
This is the part number.
Product Code: 420690NZP
Description: CONTRL CTR SD12 230V NZ/AUS SERIES 12 GW/MW ONLYBack story:
Washer having occasional problems – not addressed. then it fails.
When powered on at wall beeps incessantly and displays lights:
00110001 which thanks to Penguin45 on this forum i could see was code 49 – cold water solenoid failure. opened it up sure enough the solenoid is corroded and doesn’t function when I hook it up to a power source to test it.
I replace it with genuine F&P part – I’ve tested it, and the hot – both work fine.
When it is powered on the same beep and display.
I conclude the controller board is fried – I then proceed to poke it and the component directly connected to the cold water plug is brittle and broke easily. 😳 – not the best course of action I know, but too late now.As for the warranty the machine is out of manufactures, and we don’t have proof of purchase anymore, and I don’t think poking is covered by warranty.
I’m in NZ so parts are pretty cheap here – I have a new controller board arriving form F&P soon, they said I would need to get it programmed for my machine. – MW511 5.5kg
Questions:
Is this the size setting process?
If not how would you describe the process?
What is the procedure for doing this programing?as an aside
F&P have a good reputation here – I’ve had F&P appliances across the board my whole life, parents did too, But last year the fridge I bought at the same time as this washer died. Two appliances failing within 3-4 years of purchase is a bit rubbish.Thanks in advance
WilliamAugust 13, 2008 at 10:29 pm #259766bigsmokepiker
ModeratorRe: Fisher and Paykel MW511 replace & program motor cont
Programming is for Size Setting
There should be instuctions with new Controller
But if not
Press & hold Temp up Button then press power button
Press wash temp up button until cold LED is on
Press power to lock in & exit modeAugust 13, 2008 at 11:32 pm #259767fyodor
ParticipantRe: Fisher and Paykel MW511 replace & program motor cont
Thanks for the Assist. I apreciate it.
