Re: Fisher and Paykel MW512AU Error code 00100101
I assume water is out. Tip machine on an angle, drain pump has a cooling fan, can you turn it, is it free? If it is tight or stuck you will need to remove pump from the bowl and clear obstruction. POWER OFF wiring is LIVE.
If you cant find anything wrong with the pump stand machine up again and plug in.
Press and hold wash temp down then press power. Release buttons. Display board will light up then mostly go off. Press regular button to power pump on, press again to power off. Does it run? If it doesn’t run then you will need to find someone who is able to test the pump out.
Just guessing but your plastic bag may have overloaded the pump circuit in the module. You will need to eliminate either the pump or the module out of the problem. There is a cost to living in the country I suppose.
