Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › fisher and paykel smart drive 9 pride 5.5 error codes
- This topic has 8 replies, 4 voices, and was last updated 18 years ago by
bretto.
April 11, 2008 at 10:49 pm #35950
bretto
ParticipantI know this is an old machine and im from Australia but any help you could give would be awesome!
the water comes out in spurts when on start up then stops all together and starts beeping!
I went into diagnostic mode and got the folling error code
OFF OFF ON ON ONflashing and alternating with next 3 leds) ON ON ON (all flashing at the same time and alternating with led no 5)
cheers guys
BrettApril 11, 2008 at 11:41 pm #248826Penguin45
ParticipantRe: fisher and paykel smart drive 9 pride 5.5 error codes
Pulsing can be coldwater valve…… Use the sticky at the top of the forum (you’re in the Oz one now!) to do the diagnostics properly and report back. Model number will be useful as well.
April 12, 2008 at 2:18 am #248827bretto
thanx so much for the quick reply!
the model no is mw059au
and the lights are:
00101011
so i take that to be code 212 yes?
it also doesnt like to spin to well at the end of the cycle sometimes and starts beeping, often turning it off and on sorts this. Its doing that it now as i try to advance to spin to empty the water left in it?
it seems to be stuffed now turning it on and off makes no difference at all now….
im a sparky so am happy to do what i can to fix it but simply dont know where to start?
Cheers heaps
Brett.April 12, 2008 at 5:12 pm #248828Penguin45
43 – the good old out of balance switch fault. Faulty/wet/rotten wiring and switch to investigate. It’s the pendulum gadget under the top deck.
April 13, 2008 at 12:40 am #248829bretto
dead set legend! you were spot on! im sure you knew that anyway!
the wiring is ok but the plastic part the activates the switch was all broken and the miroswitch corroded!
i just linked out the wires and all was good!
so i just need to buy the switch and acuator assembly and re install, yea?
is that a common part to buy at a spare parts place or get direct from fisher and Pyk?
Thanx again so so much!
you doing a top job!
Cheers
Brett.April 13, 2008 at 8:09 am #248830Penguin45
There is a kit, p/no 502220, to repair the switch.
I can’t advise you on where to source components, as I’m 12,000 miles away in the wet wastelands of Yorkshire.
Cheers,
Penguin45.April 14, 2008 at 7:14 am #248831bretto
love your work!
cant belive you dont know all the local repair shops and what they stock in sydney….
thanx again so much for all the right answers!
i will be recommending this site to all i know!
cheers again!
Brett 😀May 31, 2011 at 3:20 pm #248832CoolGlobe
Hi All,
The other (100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} cheaper) option is to bypass the out of balance switch completely by wiring together the two wires that connect to that nasty little switch (part 426597 – MICROSWITCH 4.8TABS OE21-94A0.) In this way, you can simply bypass the problem switch. I just completed the repair with my mw059au now working like new once again. Ahh the pleasures of fixing your own stuff! 😀
August 9, 2012 at 11:57 pm #248833George Ng
i I think I have the same problem on my Smat Drive pride MW059NZ. Can you tell me where this pedulem switch is physically ocated? Is it at the bttom under thewashine machine and what doe it look like?
