Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher and Paykel Smart Drive GW501
- This topic has 5 replies, 2 voices, and was last updated 18 years, 8 months ago by
philip30.
July 16, 2007 at 6:13 am #29032
philip30
ParticipantI have a Fisher & Paykel GW501 Smart Drive washing machine.
When I turn the machine on and press the start button it doesn’t fill with any water, the taps are turned on but nothing happens.
After a short time it beeps and the code 00010000 light are displayed.In the diagnostic mode the lights displayed are:
10000011
Any help would be greatly apreasheated. 😀
July 16, 2007 at 6:40 am #221205bigsmokepiker
ModeratorRe: Fisher and Paykel Smart Drive GW501
Fault Code 131
Rotor Position Sensor (RPS)Error Firstly check under washer for any signs of leaking .Check connections to RPS Sensor (Sensor Is located Under bowl In Motor Area )
RPS sensor connections commonly corrode & can Cause displayed fault
If You do See Signs of leaking water in this area it will probably be due to failed main seal .Water leaks onto RPS >
The motor controller (PCB ) can also be at fault for this Code To be displayedJuly 25, 2007 at 2:46 am #221206philip30
ParticipantRe: Fisher and Paykel Smart Drive GW501
I installed another (untested PCB) and got fault code 00001001.
Fault Code 9.
What does fault code 9 mean?
Does this shed any more light on what is wrong with my washing machine ❓July 25, 2007 at 7:28 am #221207bigsmokepiker
Size Switch Error
When PCB Is Exchanged you have code in Size of Washer
Have To enter Option Mode
Power off at Console
Press & hold Start/Pause Press Power. Power OF Again to Store
To check size setting use Diagnostic Mode
IE Press & hold Washtempdown & power
If Short Wash LED on Size Is not set
If Rinse LED IS On Size is Set For 5/5.5 KG (In your case)July 26, 2007 at 2:28 am #221208philip30
When I enter Option Mode, which lights should be displayed ❓
At the moment the machine displays the follow lights.Long wash
Wash and Soak
Wash temp : Warm
Spin speed : MedThe machine does nothing and still displays fault code 9 in Diagnostic Mode.
July 26, 2007 at 5:17 am #221209bigsmokepiker
If Rinse LED IS On Size is Set For 5/5.5 KG (In your case)Check size Setting
