Hi, my washing machine stopped before the spin cycle and diagnostic tests revealed this LED code: 00101011 (0=LED off and 1=LED on).
Could anyone advise me of the likely fault? Thank you.
Fault code 43
Common OOB (Out Of Balance)Micro switch fault
Washer thinks its OOB
CHeck micro switch terminals corrode
Switch located in console under Main PCB (Motor Controller) RHS
Check that bowl is sitting central ,if hanging to side Check Bias Spring Front LHS (This Little Spring keeps bowl central )
