Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher and Paykel smartdrive 701
- This topic has 5 replies, 3 voices, and was last updated 20 years, 9 months ago by
jinkies19.
July 12, 2005 at 2:04 pm #10631
jinkies19
Participanthi – i have a washing machine model as per above – when you start a load it will begin to fill then pause then fill then pause then fill etc until eventually it stops and beeps continuously with only the 4th light on on the cycle progress bar at the top – if u press start it also turns on the last light (8th) on the bar
ive searched the forums trying to find how to get into diag mode etc and read it but cant find info specific enough as most seem to have the info emailed to them (must be copyright related) – i know the problem isnt the water valves solenoids
this problem started only a little at a time at first but has now gotten so bad i can barely limp it through the load each time now
if this is in fact the OOB switch which is talked about – how do i bypass it? and is it worth much – im mostly worried about being ripped off by a machine mechanic so id like to know the issue before i get it repaired or repair it myself if i can (i work on computers)
any help is great help – thanks!
j
July 13, 2005 at 7:53 am #141178admin
KeymasterRe: Fisher and Paykel smartdrive 701
It certainly sounds like the OOB switch. Turn the power off and remove the top console/buttonpanel. Carefully remove the motor controller and the OOB switch and bracket is on the RH side. U should see signs of corrosion. New sealed OOB switch assy P/n 420313, should be avaliable from a local part supplier. I wouldnt recommend running the W/M without it.
July 22, 2005 at 5:30 pm #141179jinkies19
ParticipantRe: Fisher and Paykel smartdrive 701
yeah im not sure im convinced – its having issues with filling tho too – could anyone let me know how to use diagnostic mode and once i have the codes let me know what it keeps trying to tell me when its beeping?
July 23, 2005 at 9:04 pm #141180KiwiwantsworkinCanada
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode. Press advance once, press the spin speed up button until the hold and slow are lit. Write down the LEDS which are lit across the top row of progress LEDS. and post back.
July 25, 2005 at 12:41 pm #141181jinkies19
ok – so when those lights are lit im getting code 1000 0010 (1 = light on)
whats the verdict doc?
July 25, 2005 at 7:24 pm #141182KiwiwantsworkinCanada
You need to check the bowl sensor on the motor for corrosion and make sure the plug is on firmly. Failing this , it could be the motor controller.
