Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher and Paykel Smartdrive 703
- This topic has 5 replies, 2 voices, and was last updated 16 years, 4 months ago by
Teco.
November 29, 2009 at 5:23 am #50534
Teco
ParticipantI have a Fisher and Paykel Smartdrive 703 washing machine that is filling very slowly on both Hot and Cold water. This only happened after I had to take out the main control board to get to the out of balance microswitch which was broken and needs to be replaced. All electrical conections look OK. Does the vacuum tube control the fill rate. Is there a way of resetting the control unit/washer or is there something that I have missed doing when I put the main board back in.
November 30, 2009 at 2:35 am #305176bigsmokepiker
ModeratorRe: Fisher and Paykel Smartdrive 703
Nothing youve done there
Common fault with the inlet Valves The internal diaphrams in the valve dont open fully to allow a better flow rate
The Valves are complete Assy with coil
Part # 426143 Cold Part # 426142 HotNovember 30, 2009 at 5:35 am #305177Teco
ParticipantRe: Fisher and Paykel Smartdrive 703
I am trying to avoid replacing both valves if I can. Both valves worked fine (fully opened, full water flow) before the I took out the main board to get to the OOB microswitch. It just seems to me that that there is something coincidental about taking the board out and putting it in again and then the valves not opening fully! Still trying to get through the 92 page service manual to find if there is a Mainboard reset function back to factory defaults or other reason for the valves not opening.
November 30, 2009 at 5:42 am #305178bigsmokepiker
No resets on these for valves (only for water temp)
Have you checked the inlet hose filters? (NOT BLOCKED )November 30, 2009 at 5:57 am #305179Teco
Both inlet screens are clean. Water is literally only dribbling through both valves. Is it worthwhile putting a meter on the valve terminal/connectors to see if its getting the full voltage. Do you know if there are any fuses in the mainboard (that may have blown)?
November 30, 2009 at 10:43 pm #305180bigsmokepiker
The only way you are going to get out of it is by replacing water valves
