Fisher and Paykel washing machine wont fill with water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Fisher and Paykel washing machine wont fill with water
Viewing 1 post (of 1 total)
  • #88549
    mealsonreels
    Good Evening Citizens
    I need some help before I go to my man cave get my 14lb hammer and beat my washing machine to death
    I have a Fisher & Paykel Smart Drive MW058K
    Product number 90103
    First problem was… I had water on the floor and it got to the spin cycle and wouldn’t spin
    I removed the inspection cover from the front bottom right corner of the outer cover and restarted the machine, looked in the inspection hole while it was performing the wash cycle and water was leaking from the main shaft, when it got to the spin cycle and the grey magnetic cover for the stator was moving clockwise then anticlockwise less than 1/4 of a turn and after approx 20 to 30seconds the machine stopped and showed an error code of 00101000
    so I took the washing machine apart
    In short I…
    Replaced damaged shaft, the seal and both bearings
    Replaced the water damaged RPS (rotor position sensor) and
    Replaced the Stator due to bad corrosion from the water leak
    all with brand new parts
    Cleaned corrosion from all wiring to the RPS and the Yellow, Blue and Red wires beside it
    Took the water pump apart and flushed clean along with the pipe and cleaned wiring clips
    I reassembled the the machine then sat down and had a couple of Speights Gold (BEERS) and patted myself on the back then plugged the bad boy in and turned the water on… fired it up AND… now it refuses to fill with water, instead of a constant flow like it did perfectly before I did all the work It lets the water in in very short bursts then stops and shows an error code of 100000011
    SO after reading some of the stuff on here I replaced the main control motor in the top panel, pushed the right buttons and got the four beeps like it said in the instructions and fired it up again
    Same problem, short bursts of water then stops and shows an error code of 100000011
    For your information: I took a Photo of the old stator and how the RPS was fitted and where it was positioned and made the new stator and RPS exactly the same and the arrows on both are aligned
    I do have one question about the grey magnetic stator cover, on the outer part of the cover it has two round circles with numbers and an arrow in each, one point to 10 the other points to 1, on the inside of the cover there is a number 11 and below the number are 3 small round raised nodules in the plastic
    any meaning to how it should be refitted back over the stator ??
    And as far as I’m aware the stator can only be fitted one way ??
    Hope there is someone who can help
    Mealsonreels
    New Zealand
