Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher and paykey 051 smartdrive
- This topic has 7 replies, 2 voices, and was last updated 20 years, 10 months ago by
admin.
May 29, 2005 at 11:20 pm #9857
KeymasterJust replaced a leaking drain hose on my fisher and paykel 051 washing machine and now it’s not working, power it on and all the lights come on, if I wait a little while the top spin light goes from left to right, surely this is just a re-set condition or somthing, nothing has been touched except for the top comming off, and the hose replaced 😳
how do I reset/get the error codes out of it
Camron
camron@optushome.com.auMay 29, 2005 at 11:33 pm #136389alexa
ParticipantHave sent you the diagnostics
Do the diagnostics and post the fault code.
To reset Press and Hold the Start Pause button then press the Power button.
May 30, 2005 at 12:14 am #136390admin
KeymasterRe: Fisher and paykey 051 smartdrive
Thanks for the reply, I haven’t recieved e-mail as yet, but I pressed the reset and the comes up with water temp adjustable, and spin speed adjustable, but no water height light, no start, so maybe I did stuff something.
I’ll wait for your e-mail
CamronMay 30, 2005 at 10:39 am #136391admin
I think maybe the control unit or somthing else important is stuffed, it doesn’t respond to much, I explained in further detail in a e-mail
Camron
May 30, 2005 at 9:58 pm #136392alexa
ParticipantCameron Wrote
Thanks very much for that, I tried the diag mode and it won’t do it for some reason, it just acts like I pressed the power button by itself, I tried it many times, trying how I did it, and using diffrent buttons etc, when you turn it on, all lights come on, then after about 5 seconds, it just goes left to right with the lights for the stage of the spin cycle.
If I press the reset that works, but I can’t press most buttons, I can adjust the water temp, and the spin speed, the water level lights are blank, and I can’t access the fast spin speed but the other speeds work and can go up and down, if I press power it turns off, and advance it does nothing, every other button (ie spin cycles and water level just beep 3 times quickly when pressed)
I read through the instructions a few times also, and I’m sure I’m doing it right, for a stage 3 diag (mw051)
maybe it’s the control unit???? any idea what a control unit is worth, just trying to work out if it’s worth trying to get it fixed or not..
Regards
CamronMay 30, 2005 at 10:37 pm #136393alexa
ParticipantSounds like you may have got water on the electronics from the leaking hose as all of these conditions are not normal.
I’d be running a heater on the electronics whilst unplugged to dry them out and then trying again.
The most likely replacement would be the top (display) module at approx $150 plus installation.
I’m at a loss to understand how you replaced the hose only from the top.
Have you replaced with a genuine hose?
Make sure you get the EXACT replacement module.
F&P on 1300 650 590 (24hrs) will send you a module. (99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} are reconditioned)
May 31, 2005 at 7:55 am #136394admin
Tried that, pulled all the boards out, there is some long term corroson on one corner of the control panel, the other bit looks ok, but still having dramas, I Think I’m going to get a new washing machine, it’s just under 10 years old now
Thanks for your help I really appreciate it
Camron
May 31, 2005 at 10:46 am #136395alexa
ParticipantElectronics, moisture and a constant voltage (albeit low voltage) causes corrosion of these boards.
A stiff nylon brush where the corrosion is and a spray with a WD40 style product (I prefer Inox) can resurrect the board.
The trick with any electronic board in a damp situation is:
1/. Turn off at the wall after each use
2/. Avoid steam.
3/. Fit a surge divertor as used on computer power plugs
4/. Ensure touch pad is not cracked
5/. Heat the room if condensation (steam) is likely to occur
- The topic ‘Fisher and paykey 051 smartdrive’ is closed to new replies.
