fisher paykal Iw811 fault code 49
Home Forums Public Support Forums International Forums Australasian Appliance Forum fisher paykal Iw811 fault code 49
  • #19178
    GregL
    Hi All,
    Can anyone tell me what a fault code 49 is on this washing machine?
    It is still half full of water and clothes and displays this message as soon as its powered up…..Thanks in advance.
    #182023
    Re: fisher paykal Iw811 fault code 49
    Faulty cold water valve, or harness to it.
    GregL
    Hi Penguin45,
    You are are spot on, and have saved me what would have probably been a couple of hundred dollars….Cheers!
    Tested voltage to water valves…Appeared to be none
    Tested resistance of valves…60 ohms…probably OK
    Pulled out the motor control PCB and gave it a wipe and more importantly reseated the wiring harness that goes to the valves….
    Put it all back together…turn it on…..and nothing happens.
    Then remembererd to turn on the taps!
    Bingo..It works again….Thanks again for the pointers.
    p.s. Also sent an email to F+P customer service requesting advice….
    still waiting…….
    #182025
    We try, even from 14,000 miles away….
    Well done,
