Fisher & Paykel 7.5kg Top Load Washer – GW712 0000101
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel 7.5kg Top Load Washer – GW712 0000101
  • #35952
    Gav1967
    HI There
    My Fisher & Paykel 7.5kg Top Load Washer – GW712 will fill with water and as it’s filing the bowl turns, then once it is full nothing happens. I’ve tried seeing if it will spin and the same thing happens all the water empties then nothing. I’ve tried looking at other posts which would be the same as mine but couldn’t find one that matched.
    I ran the sticky diagnostic and have reset the machine several times to no avail
    please could i have some advise on what to do, i’m a newb on here and need some guidance
    CHeers
    GAv1967
    #248836
    Gav1967
    Re: Fisher & Paykel 7.5kg Top Load Washer – GW712 000010
    OK latest update
    I can now get the sip cycle to work but not the main washing cycle or the rinse washing cycle.
    #248837
    Gav1967
    ALso, another update, when the machine is filling up the agitator does not move, it usually moves to even the load out when filling, and the auto level filler will only fill to a certain point then stops, if i put it on high or med fill no probs.
    can someone hel please.
    #248838
    Gavin, is this 000010 the code you were getting? If so, it’s one short. If I add another 0, you’ve got a comms error – the display board and the motor controller board are not talking to each other properly. It’s possible that there is some sort of wiring loom problem, or the boards themselves. F+P recommend substituting boards until it works – an expensive option.
    Gav1967
    Hey Penguin 45,
    The message is 00000101
    HOpe this helps
    CHeers
    GAv
    #248840
    Yup, communications error as above post.
    Gav1967
    Hi there
    My machine has actually worked one or twice since
    i find this very frustrating
    could it just be a loose wire or something like that?
    Any advice will be appreciated
    Cheers
    #248842
    Gav1967 wrote:could it just be a loose wire or something like that?
    Not much else I can add, Gavin. Comment above with regard to the loom equates to the wiring. Beyond the obvious – checking for corrosion, oxidisation, dry joints and the like on the boards, that’s about it. Pinching the edge connectors to improve contact pressure may help…..
