Fisher & Paykel 913T Dishwasher not hot filling
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel 913T Dishwasher not hot filling
  • #35534
    Flyer
    After the cold rinse cycle the hot valve isn’t opening to fill with hot water. We’ve checked out the resistance of both valves, readings 3.7K and checked all the wiring. There is no sign of burning on either the controller PCB or the power board. Any suggestions where to go next? A diagnostic routine would be helpful.
    #246985
    Re: Fisher & Paykel 913T Dishwasher not hot filling
    Penguin45 will most likely reply later today when he comes back on line as he has the relivent knoweldge.
    Bryan
    #246986
    bigsmokepiker
    Suggest you try & test if any power coming out of Bottom PCB To Hot Valve (yellow wire goes from hot valve to PCBI)f Not Youll might Need Bottom PCB
    If That is the Case Suggest using dishwasher on cold fill option only
    The Dishwasher will heat its own Water when required anyway
