Most likeley to be rotor motors jammed, remove filters in drawers and untwist r/motors, normally either cream crackred rotor motor itself or blocked/crudded up impellar. Also worth checking for blockages in drain channell were you have untwisted rotor motor, i normally prod it through with cable tie, piece of glass most likely culprit.
Hope this helps,
Chay
hi guys also had the same problem and not repaired many of these put it on and motor turns but seems a lot slower and quieter compared to other draw i tried swapping rotars but still the same won’t drain and then beeps before fill starts
customer said the none working draw fills up when the other one drains this makes me think a blockage maybe but the noise difference makes me think its trying to wash ?
