fisher paykel dd603
  • #63559
    suedehead1
    its one of those double drawer dishwashers,
    the top drawer works fine,
    the bottom drawer starts up then the light flashes constantly,
    never came across ane before any ideas or pointers welcome.
    #354128
    dave-m
    Re: fisher paykel dd603
    pm me and I’ll send you some stuff
    d
    #354129
    suedehead1
    hi again the customers been abroad thankfuly but i went back to the dishwasher today,
    the bottom drawer motor has seized i pulled of the blue impellorand the shaft wont turn,i have the service manual but its not entirley clear.
    could there be a foreign object jamming the motor is it easy to take off to check.
    #354130
    johnmac11
    It will be the rotor motor at fault, grab the pin at the top with a pair of molegrips and pull hard to get the rest out. Once out use the other motor to check that it works OK.
    The bottom motors on these sieze because the customers tend to use the top drawer all the time, simples…. 😆
    John
    #354131
    suedehead1
    thanks, does that mean it needs a new motor? do you know the part number?
    thanks.
    #354132
    johnmac11
    If the impellar comes away from the rest of the rotor motor then it is knackered, part number is 525884P
    It is possible that the motor housing might be damaged, if it is badly scored inside you sometimes get a problem where the drawer won’t empty fast enough. So once you have the old rotor motor out take the other one from the top drawer and fit it to the bottom to see if it works. If the motor housing is gone you need part number 528042.
    John
    #354133
    suedehead1
    thanks.
