Fisher & Paykel DD603 service info
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Fisher & Paykel DD603 service info
  • #91882
    char14lew
    S/N: CAM744880.
    Service information required please for this appliance. The lid won’t close on the top drawer and is leaking. The customer doesn’t want to run it due to the leaking so I can’t see the error code.
    many thanks Darrell
    #449615
    Re: Fisher & Paykel DD603 service info
    have had the lid lock motors go
    set programme and start it . you should hear the lock motors running . then stop it before it fills
    if you heard a motor run then it is probable one has gone
    have you had one apart before if no let me know but if you heard motors take the front off and with a torch you can see underneath to see the one that not working. you could also check the lower pcb at the rear where the motors plug in
    char14lew
    cheers Dave, not seen one let along had one apart! lol. I’m going back tomorrow.
    #449617
    pull draw out.
    look left and right hand side there are 2 removable pins
    remove pins and you can take front off and also allows you to unlock the draw from the runners by pushing the left and right locks to get the draw off
    beware of the 2 cables attaching the draw (drain hose, fill hose and wiring)
