fisher paykel dd603h
  • #44521
    maxx
    hi lads,having problems with this dishdrawer.found mains filter pcb.blown due to damaged heater plate in lower drawer.replaced both parts plus lower wiring loom.now display shows f1 .no water in base or corrosion to cause flood alarm .all suggestions gratefully received.maxx
    #281270
    BobHope
    Re: fisher paykel dd603h
    Hi Maxx,
    F1 is the anti flood device has been actvated for more than 6 seconds,
    did you spill any water onto it during the heater plate change ?.
    Bob.
    #281271
    maxx
    no Bob,its dryasabone.
    #281272
    johnmac11
    If the F1 fault is showing up on the top drawer and the bottom drawer is dead it means that the element in the bottom drawer is faulty.
    John
    #281273
    johnmac11
    Just remembered that if it is showing F1 on the top drawer, no water in the base and the bottom drawer appears to be OK then the fault is probably the bottom drawer controller.
    John
    #281274
    maxx
    hi John, the f1 fault is showing on the topdrawer but the bottom drawer seems to run normally. maxx
    #281275
    johnmac11
    What I said above probably applies, the bottom controller is what tests for a F1 fault. Try swapping the controllers round if it is a fault with the bottom controller and you swap top and bottom the machine will work fine.
    Also worth noting that F1 is usually a flood problem but if no signs of a leak check both elements for a blown thermal fuse.
    John
    #281276
    maxx
    thanx lads,ill check the heaters. maxx
    #281277
    johnmac11
    johnmac11 wrote: if it is showing F1 on the top drawer, no water in the base and the bottom drawer appears to be OK then the fault is probably the bottom drawer controller.
    maxx wrote:f1 fault is showing on the topdrawer but the bottom drawer seems to run normally
    Check the controller..
    John
    #281278
    maxx
    thanx John, new contoller on order!will be nice to put this one to bed.
    #281279
    johnmac11
    Did you swap the top and bottom controllers around??
    John
