Fisher & Paykel dishdrawer
  • #47689
    chezza
    Hi all , any experts out there on these beauties ?
    I had a dd603hfc last week knocking house electrics out . I found rinse aid dispenser overfilled, and dripping between panels on the top drawer, which corroded the sensor wires in the dispenser and shorted to the drawer front. I sorted this and tested, then left the unit running on the rinse cycle when i left . Got a call back saying the rinse finished ( and drawer is empty and clean ) but when c/r went to use it again, it is dead – no power at all to the top . Bottom drawer is unaffected and working fine . Any suggestions ?
    Thanks in advance, Eddie
    #294271
    jwd_73
    Re: Fisher & Paykel dishdrawer
    Heater plate open circuit, loom burned out,control module burned out or mains filter board burned out or if you are unlucky a combination of all the above.
    My money is on heater plate solder/fuse has hit another track caused by the rinse aid drip.
    #294272
    chezza
    Thanks pal, I’m going this morning so I’ll report back 😆 cheers
