Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Fisher Paykel Dishdrawer
- This topic has 8 replies, 4 voices, and was last updated 15 years ago by
nigegt.
March 16, 2011 at 8:01 am #61678
nigegt
ParticipantDD603H
The top try is dead, Half way through the cycle it just died. Been to plenty of these and thought i knew ’em inside out but the only conclusion i can come up with is that there must be a break in the wire from the power board to the pcb but i metered each wire and got no breaks 😕 , Has anyone had this happen? (I’ve even powered the upper tray with the lower supply and it works fine)
Nige
March 16, 2011 at 9:43 am #347187eastlmark
ModeratorRe: Fisher Paykel Dishdrawer
could be the thermal link in the heater element. its used as a resistor to power the board in the draw front. New heater is the only fix if so.
March 16, 2011 at 2:41 pm #347188nigegt
ParticipantRe: Fisher Paykel Dishdrawer
Thanks mark but top tray powers up if connected to lower tray supply and works fine. Going to order wire and post with results. Fingers crossed!
Nige
March 16, 2011 at 4:30 pm #347189eastlmark
sorry didnt read your post properly. Shirley then it must be the power board?
March 28, 2011 at 8:36 am #347190nigegt
Ok so changed upper loom a it lives again! But wont go through a full wash, Goes about a third through the cycle and holds but no fault code. Help!
March 28, 2011 at 8:18 pm #347191johnmac11
If it jams at the 24/25 minute mark then it is a faulty heater plate.
JohnMarch 30, 2011 at 3:01 pm #347192nigegt
Been back this morning to look at this and it stops at 60 mins and after heating and wont move to the rinse, cust said if left it will just wash ’til the cows come home. Could this still be a dodgey heater plate? No fault code and non stored either.
Nige
March 31, 2011 at 12:47 pm #347193johnmac11
Hi Nige,
I would still say that the heater is faulty, you would need the resistance readings to be sure. Have you got the manual??
John
April 1, 2011 at 5:00 pm #347194EFS
eastlmark wrote:sorry didnt read your post properly. Shirley then it must be the power board?
Nigel only goes by that name on Thursday nights. 😉
Steve
