when lower drawer selecter sounds like wash motor sqealing, also some water leaking out from top of bottom drawer, havent worked on these before,
any pointers…cheers ally
If it’s noisy when washing the rotor my be worn it’s a twist fit once you got the filter out of the way just turn anticlockwise and pull it out if the blades are damaged (on the inside end)you will see it easily. If its not too bad you can trim the bits that catch, if not replace it. You can swop it with the rotor from the top tray also just to test and see if that stops the noise.
