Fisher Paykel DS605 dish washer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Fisher Paykel DS605 dish washer
  • #73568
    Kez
    Can anyone help with any technical info on this dish drawer have only done a couple before and both have been the rotor motor, however this one is a different fault as it wont drain or is stopping full of water. The rotors have been swapped over from top to bottom.Its the top drawer we are having problems with. Cheers Kez
    #388001
    Cras
    Re: Fisher Paykel DS605 dish washer
    hi ,been out to this dishdraw today customer reports fault with top draw only ,when we arrived this morning the dish draw had stopped full of warm water ,no beeping error codes,etc he told me he had tried it on every wash and it did the same except for rinse cyle which it completes ok at a bit of a loss really, it drains manually ok . Any help with this gratefully received or any tech info please Thanks Cras (works with kez)
    #388002
    jwd_73
    HI
    How high is the water when the drawer stops? is it over the rack at the bottom?
    what happens when the drawer stops does it beep 3 times every minute and if it has a display is there a dish symbol flashing?
    or if no display does the blue light flash?
    Reason I ask is could be infa-red issue causing the drawer to pause when hot.
    Newer control modules have an offset prism to stop this issue (the old way was to add a spacer onto the right hand runner to lift the right side up by a few mm)
    John
    #388003
    Cras
    Thanks for the reply ,no this just stops no flashing lights ,i cant remember how high the water is but i will check .I have read an older post with the same fault stating it also could be the heating element even though the water is warm when it stops so im going back to check that ,any thoughts Thanks Cras
    #388004
    Cras
    It was the heating element ,for anybodies future reference 😀 😀
