fisher paykel element
  • #66285
    ELDAR59
    we need an element for a fisher and paykel fan oven. the trouble is, the rating plate has been wiped clean and the only numbers that the customer can give us are:-
    BI453
    BI603
    neither of which are recognised by connect.
    although connect do list a fan oven element, there’s no picture of it.
    the element has a long neck and the fixing on the other side is on the inside of the ring.
    is anyone familiar with this?
    cheers.
    #363699
    johnmac11
    Re: fisher paykel element
    If it is a BI603 then the part number you need is 542959P
    John
    #363700
    ELDAR59
    thanks john, i’ve just typed that into the search box on connect and i don’t think it’s the same element.
    the neck on the one on the appliance is long and thin. the one above is much wider.
    thanks again for your help.
    cheers.
    #363701
    johnmac11
    Looking on CDSL and it appears to be the wrong element in the picture but they might be using a generic picture for it, type the part number into the shop here as it is listed and has the correct picture.
    John
