Re: Fisher & Paykel Fault Code????
Depends which Way your Reading Lights
If As posted Fault Code 208 There is no code listed
If We Read it As 00001011 Fault code 11 Pressure Sensor fault
Check Pressure Tube has not Dislodged or Clogged Blowing thru tube can Clear any blockages
Secondary Fault could be to due to faulty Display Module (Top PCB)
Pressure Sensor is Integrated Into The Display Module.
Note When checking/removing pressure tube ensure there is no water in The bowl
