fisher paykel fridge freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries fisher paykel fridge freezer
  • #51899
    spuzzer
    hi we have customer with e522b ff freezer ok but botom of fridge is freezing up have changed thermistors but has made no difference both thermistors that were sent too us were the same not sure if thats correct any help would b good on this one many thanks
    #309797
    jwd_73
    Re: fisher paykel fridge freezer
    Test if the fan at back of fridge is working.
    the fan is situated behind the backplate inside the fridge odds are you will find that one of the wires that go into the fan has broken.
    Very very unusual to be a thermistor/sensor prob only ever changed 2
    Good luck
    #309798
    spuzzer
    thanks for that fan is working ok though so we are a bit at a loss with this fault.
    #309799
    don
    Hi spuzzer
    Iv`e deleted this post from the public forums and added it to your existing topic.
    spuzzer wrote:Hi can anyone help with this appliance that our customer has freezer works ok fridge too warm in bottom fan running ok changed both thermistors which arrived too us as same for both fridge and freezer not sure if thats correct but appliance still the same any thoughts would be good thanks
    Best to keep it to one thread and out of the public domain.
    Don
    #309800
    spuzzer
    don wrote:Hi spuzzer
    Don sorry thanks 4 that
    #309801
    johnmac11
    spuzzer wrote:freezer ok but botom of fridge is freezing up
    spuzzer wrote: freezer works ok fridge too warm in bottom
    Which one is correct?? if it is the latter it will either be one of the fans or the defrost element which is causing the fault. I have never changed a sensor in one of these fridges.
    John
    #309802
    spuzzer
    hi god having a nightmare this week its the fridge which is too warm freezer ok and fans running ok
    #309803
    jwd_73
    Ok if both fans are ok no loose join at the fan end for the top fan or where the wires are pinched for the bottom fan my next guess would be…
    Defrost heater could be open circuit or the heat transfers that clip on the heater and go to the backplate could have fallen off causing a block of ice to build up in the air vent behind the evaporator.
    Good luck[/img]
