Fisher & Paykel GW501 Smart Drive code 37?
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel GW501 Smart Drive code 37?
  • #29458
    sam__kent
    Hi there,
    I have a Fisher & Paykel GW501 Smart Drive that has not been working properly. It has been stopping part-way through spin cycles and giving no error beeps – it just shuts down.
    The last time I tried to run it empty, there was a burning smell as it tried to pump out the water. I shut it down, googled how to get the diagnostic code, then got a series of lights up that add to 37. I also have a photo of the panel that I can e-mail for confirmation, if required.
    What does this means?
    Thanks in advance.
    #223150
    bigsmokepiker
    Re: Fisher & Paykel GW501 Smart Drive code 37?
    Fault Code 37 Pump error
    Either something jammed in pump or Pump itself Faulty
    Pump Located under Washer
    It sits under Bowl
    Give Fan of Pump A Bit of a Tweek and it may free up Whatever is Stuck in there
    If not you may have To remove pump
    It Twist locks off & On the Mounting bracket
    Check pump for signs of Water leakage
    Pumps do have a Overload if they get to hot will shut Down
    Power OFF
