Fisher & Paykel GW501 washing machine stops mid-cycle
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel GW501 washing machine stops mid-cycle
  • #40940
    atomantb
    My washing machine keeps stopping mid-cycle and both the hot and cold water temp lights flash. I’ve tried to put it in diagnostic mode using the instructions found in this forum but they don’t seem to work on my machine..
    Can anyone help??
    #268113
    bigsmokepiker
    Re: Fisher & Paykel GW501 washing machine stops mid-cycl
    Hot & Cold Lights Flashing is aUser warning that there is No water
    IE Could be Slow flow rate /Blocked filters /taps turned off
    When you say stops mid cycle at what stage is this ?
    #268114
    atomantb
    Thanks – has been fixed now.
    FYI – if anyone else has a similiar problem it turns out it was a hole in the cold water inlet valve, a pretty quick fix, only cost about $45 for the part.
