Fisher & Paykel GW508U – cold inlet v. slow, error code
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel GW508U – cold inlet v. slow, error code
  • #32473
    npeters
    Hi – Our Fisher & Paykel Smart Drive GW508U washer (according to the label on the back) has a problem – the cold water inlet flow has slowed to a trickle.
    I have had the nozzle assembly out and made sure it is clear.
    Warm water inlet is OK – flow speeds up when this is selected.
    The error code is 160 i.e (10100000).
    Will a new cold water inlet valve fix this problem or is it something else?
    Any help or advice is appreciated.
    Norm, Canberra
    #235266
    Re: Fisher & Paykel GW508U – cold inlet v. slow, error c
    The code does not relate to the water valve, it relates to the drum not floating up the shaft. This would make sense as the motor will start operating after a set period, expecting the drum to be afloat. Slow fill will prevent that.
    I’d replace the valve and see what happens. P/no 426143.
    npeters
    Many thanks Penguin – I will order a valve tomorrow & post what happens.
    Cheers
