Fisher Paykel GW608 one second beeps and 01101000 104 code
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher Paykel GW608 one second beeps and 01101000 104 code
  • #46745
    MAR01
    Current problem is it beeps at one second intervals, and gives fault code
    01101000 = 104 on the lights (Model GW608). Anyone with any ideas of how to fix the problem.’Brooksi’ said he fixed the problem in a previous post but doesn’t explain how he did it.
    When I turn power on at the socket to the machine…the pump is continuously running. If I pour water into the machine the pump will empty the water. If I lift the lid, the pump stays running.
    Any help would be really appreciated.
    #290727
    bigsmokepiker
    Re: Fisher Paykel GW608 one second beeps and 01101000 104 co
    From pas t experience seems like a motor controller fault(Main PCB)
    If pump running all the time PCB is sending power to pump continously
    Part 426204p About $200.00 AU
    #290728
    MAR01
    Thanks for your reply. I have phoned a repair guy and will update on how it was fixed.
    Thanks again…really appreciated
    #290729
    MAR01
    Appliance guy called and fixed the machine. It was the motor controller as suggested. Thanks bigsmokepiker for the advise. Much Appreciated
    Total cost NZ$216
