fisher paykel gw608 where is the fuse?
Home Forums Public Support Forums International Forums Australasian Appliance Forum fisher paykel gw608 where is the fuse?
  • #39337
    farmerpete
    Someone told me once there is no such thing as a dumb question….. so here goes :
    Where is the fuse on my gw608 machine? or is there no fuse?
    I have no power to machine at all.
    Any help would be great thanks.
    #262167
    Re: fisher paykel gw608 where is the fuse?
    On the motor controller pcb.
    farmerpete
    Thanks for the reply penguin.
    Got the PCB out, can you please describe the fuse to me and how to check if it is stuffed, thankyou.
    #262169
    bigsmokepiker
    Fuse is in the motor controller (main PCB)
    Check with meter
    Note If fuse this usaually blows for a reason But for the price of a new fuse its worth a try
    Also bw aware the pump forms part of the power circuit in this model
    The pump or Wire to pump may be the culprit
    #262170
    DaveP68
    The pump “only forms” part of the power supply circuit for a series 9/10 (phase 5) grey in colour motor controllers installed in models LW095, MW059, GW509, IW509, GW609, GW709 etc.
    The model referred to in this post is a GW608 which is a series 8 machine (phase 4).
