Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher & Paykel GW611 no drive??
- This topic has 9 replies, 3 voices, and was last updated 20 years, 1 month ago by
zweetpeaz.
February 12, 2006 at 5:32 am #15587
zweetpeaz
ParticipantHi all,
cant seem to get the old machine through a cycle. The machine fills but there is no action from the drive motor. At times i can turn the machine off at the wall for 60secs and restart it all, but now she is not starting the motor at all. On spin cycle the pump motor works fine and the resistances are as the same as another posts specs so???? I have gone through the diagnostis and found the code to read.00111000
Can anyone help? thanks Dean:(
Also, what gets you out of diagnostics??
February 12, 2006 at 6:26 pm #164176Penguin45
ParticipantRe: Fisher & Paykel GW611 no drive??
It’s probably the Rotor Position Sensor playing up. These are prone to corrosion and wiring problems. It can also be the Motor Board, which is expensive, so keep your fingers crossed…..
Power off if going into the motor.
Powering off should take you out of diagnostics……….
Penguin45.February 12, 2006 at 8:20 pm #164177zweetpeaz
Checked the motor position sensor and stator condition. All looked fine, no corrosion.
Being a frustrated motor vehicle technician, I have pushed many buttons trying different things from other posts, I now have the 3 rinse/spin lights flashing.
Power off is not clearing them. They are on as so as you switch the power on from the wall.
Any other suggestions? And is the motor control board repairable? I cant see any burn / overheating marks on any component?????
February 12, 2006 at 9:52 pm #164178Penguin45
Being merely Avian, I have sent for a higher authority – bear with us!
February 13, 2006 at 11:23 pm #164179FastAndPro
your coming up with Fault code 56 lid lock fault and will stop the spin this is a regular fault on the brown modules theres nothing with the lid switch its the module would recomend you get a pro to fit it so you get the correct fault as its only a 99.5 {e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} guess and you get the waranty as well for some reason if you unplug the machine for a day or two this fualt sometimes fixes itself we turn up the fault codes there and the machine works ??????
February 14, 2006 at 11:32 am #164180zweetpeaz
ParticipantNo No! it still isnt working. Today i had tried it from powering up the machine from the wall. It had started the cycle, put a few items in the machine then!!!!!!! the water continues to flow but the motor stops, the water fills to the level requested but the next step isnt taken. No motor!! Progress light are on but no progress……..
February 14, 2006 at 12:36 pm #164181zweetpeaz
Participantwhere are you fixing gurus?????? the smartdrive may get a real test when its flying off the balcony. F & P will have to call it auto pilot if it does pull out of its dive!!
February 14, 2006 at 9:19 pm #164182Penguin45
Participantzweetpeaz wrote:where are you fixing gurus??????
Personally, I was out for 10 hours earning my living repairing people’s appliances….
Look, we’ve told you what we can remotely – if you’re not winning and you want to keep this one going, you’ll have to bite the bullet and get pro help.
Good luck,’
Penguin45.February 14, 2006 at 10:42 pm #164183FastAndPro
“its 99.5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} the module would recomend you get a pro to fit it”
February 14, 2006 at 11:28 pm #164184zweetpeaz
Ok thanks guys. I’ll chase it up. thanks for your help and I’ll post the results for you.
Electronics! buggered with them Buggered with out them!!!
