Fisher & Paykel GW701 Fills & Drains
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel GW701 Fills & Drains
  • #26130
    verylost
    hi there, washering machine starts fills to level starts washing then starts to fill with more water and drains at the sametime. Checked fault codes found 132 could you help please.
    #208911
    Re: Fisher & Paykel GW701 Fills & Drains
    Short circuit in motor or wiring harness can cause this, as can the rotor position sensor being out of position, causing false readings. Fill and empty (you didn’t say if the pump was running or not) together can also be a syphoning problem – end of drain hose too low in outlet pipe.
    verylost
    hi there no the pump is not running i am just about to remove front cover to check wiring harness ?? also washer been in same spot for more than 5 years, but outlet could be to low ??
    #208913
    silvercody
    hi,try blowning hard down the pressure tube on the side of the bowl .turn off power dissconnect from top.
    #208914
    verylost
    hi there, problem fixed found rotor position sensor being out of position and wiring loom damaged, repaired and retested ok. Can you help on how to reset fault codes ?? thanks for the help 😀
    #208915
    verylost wrote:Can you help on how to reset fault codes ??
    You shouldn’t have to…….. Last fault is retained in the memory for 8 (I think) washes – if no recurrence, it should delete by itself.
