Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher & Paykel GW701 noisy drum
- This topic has 5 replies, 4 voices, and was last updated 17 years, 10 months ago by
cankiwi.
June 5, 2008 at 9:48 am #37195
cankiwi
ParticipantMy F&P is 14 years old. Yesterday I changed the OOB switch and noticed that when I manually turned the drum it is stiff and made a noise that sounded like a piece of cardboard flapping on the spokes of a bicycle wheel. The drum did not turn smoothly but had increase resistance (jerky) that concided with the flapping noise. The machine “works” normally. I cannot remember hearing this noise before. Is this noise normal?
June 5, 2008 at 9:50 am #253831iadom
ModeratorRe: Fisher & Paykel GW701 noisy drum
Moved your post to the dedicated, Down Under forum. 😉
No doubt one of the F&P experts will be along to answer your question soon.
June 6, 2008 at 12:21 am #253832Penguin45
ParticipantRe: Fisher & Paykel GW701 noisy drum
The drum will not turn freely due to the rotor moving past the magnetic fields of the stator – it should feel like it’s “pulsing” gently with light resistance. If you are actually getting noise, I would check that the rotor is fully secured by it’s central nut and also to its reinforcing plates. If the rotor is clipping the stator, major damage could quickly ensue.
June 8, 2008 at 7:29 am #253833kiwireeferman
If you changed the out of balance switch is the lever rubbing on the bowl?
June 8, 2008 at 8:49 am #253834cankiwi
Checked all that I could. The rotor is not contacting the stator and the oob arm only contacts the outside of the bowl enclosure when it is out of balance. How do I remove the top panel to remove the inner rotating drum? or is there another way to check how secure the rotor is attached to its reinforcing plate. Removing the agitator does not show anything. The noise is only there when the inner drum is rotated manually. It seems to operate normally and quieter under power.
Thanks for all the advice offered.
June 8, 2008 at 12:10 pm #253835Penguin45
You won’t have to remove the top deck. The rotor and stator make up the motor, which is bolted to the bottom of the tub – access from underneath.
Power off first – the pump is live if the machine is plugged in.
