When I turn the power on to the machine GW711 F & P at the power point the washer powers up & does it’s start up cycle & then starts to beeps every second with the the third & forth wash progress lights from the left on (green) & the spin light on ( red)
When start/pause button is activated the lid light comes on & the other lights go out with the beeping stops.
If I push the power button the lid light goes out & the other lights come back on with the beeping.
I have tried to get a fault code but this function does not work, I have been reading through other questions & answers on this site & thought it may have been a cold water solenoid or wiring. I have check both solenoids with reading of 64 ohms cold & 65 ohms hot. I don’t think this would be the problem, it’s looking more like maybe the controller module is at fault.
As I said before the control panel comes on straight away when I turn the power point on the wall on.
Any help would be good thank you
