FISHER PAYKEL GW711 ERROR CODE 01000010 (code 66?)
Home Forums Public Support Forums International Forums Australasian Appliance Forum FISHER PAYKEL GW711 ERROR CODE 01000010 (code 66?)
  • #34473
    knockabout
    G,day,
    My machine just started playing up and giving me the error code 01000010 (code 66?). It will start to fill up, then agitate a little bit then stop. The spin and drain seems to work fine. If i start another cycle after the machine has stopped it will over fill.
    Thank You
    #242819
    Re: FISHER PAYKEL GW711 ERROR CODE 01000010 (code 66?)
    Level switch problems. Check that the air hose is not holed, kinked or trapped. Failing that, it’s the motor controller board – the level switch is an integral component.
    knockabout
    that was quick! 😀
    I had the motherboard replaced not long ago so i hope its no the control. Ill check the hose and get back to you
    #242821
    knockabout
    G,day Penguin 45,
    Just running it through a cycle now with the water level set to low. Seems to be working fine at the moment. No kinks or small holes in the hose so i just fitted it back. Could it have been a loose fit somewhere, confusing the pressure sensor?
    Cheers! :happy:
    #242822
    knockabout
    G,day Penguin 45,
    It has almost completed a full cycle!! Yay. Why does it seem to always work after I turn the machine on its side? ❓
    #242823
    The air hose connects to a chamber at the bottom of the drum which traps air. The rising water forces air up the tube to work the level switch. By tipping it over, you may be clearing any retained water from the chamber. It could be sludged up, or possibly be obstructed in some way. Might be worth pulling the inner drum out and seeing what’s happening down there.
    knockabout
    G’day peoples,
    Its playing funny buggers again. this time the fault code is
    00000001 L-R on the lights. Any ideas??
    Cheers
    #242825
    Motor control board fault. Ouch……..
